Attaching C-11 to mount by yourself
Started by cyclops37, 09/14/2013 02:59PM
Posted 09/14/2013 02:59PM | Edited 09/14/2013 02:59PM Opening Post
Any hints or tips on attaching a C-11 scope to a mount without hurting yourself?!
I find it very difficult to hold the scope alone while guiding the dovetail bar into the mount.
Posted 09/14/2013 07:09PM #1
The best cure I know of is getting a saddle that opens up rather than one you have to slide it into.....more $$ I know but worth every penny.
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 09/19/2013 02:40AM #2
As others have commented, a tip-in rather than a slide-in dovetail saddle helps. For my C14 I use this process: I place a tall table next to the mount (like a camping table with home-made extensions on the legs) -- it needs to be about the same height as the pier or tripod. I put the C14 on the table, then turn it so it is pointed nose-down, slide it over to the mount, set the mount so the Declination axis is horizontal, and then attach the C14 to the dovetail saddle on the mount. Then I put the counter-weights on the mount and let the mount do the heavy lifting. Once the mount has lifted the scope off the table, I'll move the table away.
Posted 09/29/2013 12:37AM #3
In addition to the Casady saddle mentioned above, you could use a length of 2x4 to prop the CW shaft up in a horizontal position with counterweights already on - then you can sit the dovetail in the saddle, hold the OTA against your chest with one arm and tighten the saddle knobs with the other hand. I find this much easier than lifting above chest height.
You can drill a hole through the 2x4 to slip the CW shaft into to avoid the wood falling away while the tube is being mounted.
