From the
ATWB Customer Gallery
IC410
Losmandy AZ-8 Alt-Az due out early 2015
Started by Greg Shaffer, 12/19/2014 01:47PM
Posted 12/19/2014 01:47PM | Edited 12/19/2014 03:16PM Opening Post
The Alt/Az mount, Part # AZ8 List $800.00 with tripod (scroll to bottom for pic)
All machined aluminum and stainless, black anodized
All stainless steel hardware
Two 2.100” diameter needle thrust bearing
Two 2.000” diameter needle thrust bearing
Duel saddle plates that accept Losmandy D series and Vixen V series dovetail plates
2.812” diameter, 7075 aluminum worm gear, 180 tooth, both axis
Dual supported, ball bearing housed ground High Precision Brass Worm
Variable slip clutch, both axes. One knob per axis design
Slow motion knobs both axis
Will accept our 12288 line encoder, Part # DSCH
Will accept the Gemini 2 GoTo system for Alt/Az GoTo
Four 1.500” diameter needle bearings
1.25” diameter aluminum shafts
Adjustable height tripod. 30” to 44”
Additional 6” riders
This is a GM8 mount machined into a Alt/Az mount design
40 pounds of equipment weight
Photo is a prototype. It will be all black.
Greg Shaffer's attachment for post 58951
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Statham GA
Posted 12/19/2014 01:48PM | Edited 12/19/2014 01:51PM #1
2nd pic
Greg Shaffer's attachment for post 149044
Celestron C11
Statham GA
