most of the fun stuff is done anyway. This is a hybrid (too pretty to call a Frankenscope) made from a 12" Lightbridge and a 12" Zhumell (both GSO scopes). The top tube and trusses are LightBridge and the bottom is the former top of a parted-out Z12. I chose to use the top end of the Z12 to experiment with a boundary layer fan. It will blow across the primary through the 3" hole that used to host the focuser. I installed original-model aluminum adjustable alt bearings. Everything is going to get painted an attractive medium gray.
The base is a knock-down dob base that weighs only 21 pounds. The stock base weighs 40 pounds and is 5" taller. It's most eye-catching feature is an operational planisphere in the groundboard. The 400 stars and Milky Way are wood burned into the knotless Baltic Birch. I plan on staining the uprights and base with MinWax Ebony stain and just clear varnishing the groundboard.
I still have to install the flocking, Astrocrumb filter slide rails (original style), and 3" boundary layer fan. I already have an Astrozap light shroud ready to install when everything else is ready. I rotated the spider 45 degrees to accommodate the filter slide. I also rotated the focuser 45 degrees for ease of use. The top end has the bases for a Telrad and optical finder. I still need to wood burn the numerical labels for the dates on the groundboard and the dates on the base.
Customized Zhumell Z12 on Dedicated Atomic EQ Platform
Customized Hybrid Z12/Lightbridge on Baltic Birch Planisphere Mount
(I'm holding famous Martian meteorite ALH84001 in the picture.)
