You want to work COC, not the W stroke.
IF you dug a real hole hogging out to depth, then you will need to obtain contact with 80 grit; 120 will take a very long time to get there, especially on an F4 or faster. Go back to the 80 grit, work centre over centre, 1/3 stroke until contact is obtained. You can return to work MOT or TOT as required to control the sag once you obtain a spherical curve.
hope this helps,
dan
hope this helps,
dan
