From the
ATWB Customer Gallery
My First WOW image
Saturn Observation (12/15/2002)
Started by Martian, 12/15/2002 12:40PM
Posted 12/15/2002 12:40PM Opening Post
I would like to wish everyone the best of holidays and a Happy New Year. I have attached my latest observation of Saturn using a different instrument (8-inch F/5 Konus Newtonian reflector). I hope that you like it.
Date (U.T.): December 15, 2002
Time (U.T.): 02:20
CM1 270.4, CM2 231.4, CM3 304.0
B (Saturnicentric latitude of the Earth): -26.5
Instrument: 8-inch (20-cm) F/5 Konus Newtonian reflector
Magnification: 203x
Filter: None (IL)
Seeing (1-10): 5-6, Antoniadi (I-V): III
Transparency (1-6): 2-3 (Hazy)
Notes:
Globe:
South Polar Region (SPR): Appeared dusky to dark (3-4/10) without any other detail visible.
South South Temperate Zone (SSTZ): Appeared dull (5/10) and greenish in color.
South Temperate Zone (STZ): Appeared shaded (6/10) but no other detail visible within.
South Temperate Belt (STB): Appeared dusky (4/10) and thin.
South Tropical Zone (STrZ): Appeared bright (7/10) and no other detail noted within.
South Equatorial Belt (SEB): The southern half appeared dusky (4/10) whereas the northern half was dark (3/10).
Equatorial Zone (EZ): Appeared bright (7/10), but no other detail visible within.
Rings:
Ring A: Appeared dull (5/10), but the Encke minima (or division) was not visible at this time.
Ring B: Appeared bright (7/10) but no other detail visible within.
Ring C (Crepe): Appeared shaded (6/10), but no other detail visible within.
Carlos
Martian's attachment for post 2666
Posted 12/15/2002 03:11PM #1
Hi Carlos,
Thanks for showing this one.
Sol Robbins
Posted 12/20/2002 08:19AM #2
Very nice drawing and notes! Thanks.
Posted 12/20/2002 01:30PM #3
Mike,
You have pointed out a very interesting aspect of Saturn's rings with respect to their brightness variations. Ring A (outer ring) is usually dull (5/10) and may exhibit the infamous Encke minima (or division) . The Encke Division may be detected under steady seeing conditions using at least a 6-inch refractor or 8-inch Newtonian. Ring B (middle ring) exhibits the greatest variation in brightness due to it's diameter and proximity to Saturn (globe; ring particles reflecting a more intense (lumens) light from the globe). The outer portion of this ring does appear brighter than the inner half. This is due to variations within the ringlets (as we all know the rings are actually made up of thousands of ringlets as shown by the Voyager spacecraft). The passage of Saturn's magnetic field over the rings as the planet rotates may also affect their reflectivity (brightness). Ring C (Crepe, inner) is the darkest of the three major rings. This ring is most noticeable as it crosses the globe. At times spokes (radial dark features) are visible over the inner aspect of Ring B and may therefore "darken" this portion of the ring.
A reason that the the rings may appear more "homogenous" in CCD images is that processing (software) may "average" the brightness of the ring. The eye can pick out the subtle variation within the rings. A good example where the eye (if properly trained) can be an excellent detector for fine detail over the planets.
The best of luck in your own observatons and Happy Holidays.
Carlos
