Perhaps I irritate a tad too easily, but I grew extremely tired of having to use a tiny allen wrench every time I needed to orientate the focuser on my Lunt 60mm H-a scope that has the FeatherTouch focuser. Then after I got finished with my viewing session and wanted to store the scope in the case I would have to loosen those same screws back up to get the scope to fit back in properly.
So I did some measuring and headed towards my favorite hardware supplier, McMaster-Carr. I found the perfect stainless steel knurl headed thumbscrews. One could get by with replacing only 3 of the 6 screws, but I went ahead and replaced them all just to keep the looks.
If anyone else is interested in doing this easy and reversible mod, I can supply the catalog number and specs. The silly things are $3.00 each, but McMaster also has a black plastic headed variety that would work that was quite a bit cheaper. All of the other knurled knobs on the scope are knurled stainless steel which is why I went this route. I also put these knobs on my Lunt 60mm CaK scope. This has made my setup much easier and faster with no dropping that tiny allen wrench or those small hex set screws! I guess it's the little things in life!!
