Herb,
Do believe there will be a point that you have crafted the support, sponsor function is such a way that there will not be this constant campaign for funds? The desired effect would be to have the members of Astromart not need the prodding and provide the funds required.
However, relying on the group as a whole doesn't seem to work, and usually when that happens it is due to a lack of clear direction. When you say the site is in danger some respond because you have given clear instruction at a particular level, but that group is still the minority. That would lead one to believe the message still isn't clear enough, because if it were then a majority would respond. I don't believe that has happened because if it had then you would not need to send out dire messages about the site failing.
I am not looking to suggest a way, you clearly have a vision, only wonder if the final goal is to set up the fund collecting in such a manner that doesn't require years of discussion and lots of your stressing whether this site can stay afloat.
Gerald
Gerald
