CG5 Motor Run Time
Started by epg71117, 01/27/2022 11:12AM
Posted 01/27/2022 11:12AM Opening Post
I started having problems with my CG5 mount.  The RA would only operate in one direction.  I purchased a new hand controller and it worked intermittently.  I removed the motor and was able to run it in both directions.  I found the motor will run for 180 seconds and stops. This happens in both directions.
Is this a motor problem or a controller problem?  Note the motor was run free with out any load.
I tried the Dec motor and it ran continually in both directions.
My question is the RA motor failing?  Or is that the normal operation.
Does any one have a good motor for sale.  It is the older 4 wire motor.
The only reason I asked about it may be a controller problem was I set the horizon limits on my old controller.  I doubt is is a controller problem because I tried retting the old controller  and it did not help and the new controller has never been set to limit the travel.
Any suggestions are appreciated.
Posted 01/27/2022 01:40PM #1
1. You saved the same post 4 times.....Try refreshing your screen once you have saved a post.
2. You might get better results by posting your questions on mounts in the Mounts forum instead of the FAQ forum.
3. If you are interested in buying mount parts such as a motor, you will definitely have more success by posting a wanted ad in the classifieds section instead of in the message forums.
4. Welcome to AM.....
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 01/27/2022 09:31PM #2
How do I delete the multiple post?
Posted 01/29/2022 10:59AM #3
The delete option is not offered here.....edit only.
Celestron C11
Monroe GA
