Rating a member.
Started by DavidJJ, 05/28/2019 02:56PM
Posted 05/28/2019 02:56PM | Edited 05/28/2019 02:57PM Opening Post
Good morning,
Just end a transaction with a member and I'm trying to give a rating but through your profile I do not see the possibility, what could be happening?
Thanks!
Posted 05/29/2019 03:18AM #1
Originally Posted by David Jimenez
Good morning,
Thanks!
Its not on HIS profile.....its on YOUR profile. Open up the "My Account" page and look for the section called "Ratings"....you should be able to figure it out from there. You are looking for "Unused Ratings".
If you have responded to someone's ad they will be listed there. If you completed a transaction with them then you should use the rating option for them. However if there was no completed transaction you should delete the rating flag for them. Rating are intended only for transactions that were actually completed.
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 05/29/2019 03:45AM #2
Thanks Greg,
If I enter in my account for unused ratings, the name of this member does not appear.  If I enter in my received messages “inbox” and open a message from another member, once in the message if I pulse on their name it allows me to rating “use this rating “.
All the best.
Posted 05/29/2019 06:36AM #3
I assume you mean someone else besides the person you are trying to rate. The only way that should happen is if you also have responded to one of their ads as well.....
However now that I checked into it the new site software also inserts a "use this rating" when you view someone elses profile if you have responded to one of their ads. So now there are two ways to go about it.
However if they are not showing up in your "unused ratings" list then for some reason the system has lost the rating flag. If they have not marked the item as sold yet you might see if there is still a "respond to this ad" on the ad and respond again.....that should create a new rating prompt.
Celestron C11
Monroe GA
