rotate pictures
Started by Mercury593065, 06/27/2020 01:57AM
Posted 06/27/2020 01:57AM Opening Post
How do you rotate pictures?  When I added my photos, to my ads, the picture
was "upright"  When I view my ad, the pictures are all rotated to the right.  How
do I get them upright?
Posted 06/28/2020 07:29AM #1
Have seen this before. I edit the pics using an image editor such as photoscape (a free one) and saved them again. Then uploaded them to AM, problem solved.
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 11/06/2021 10:41PM #2
Nope for me.   rotated mine in Pictures file and still went in upside down
Posted 11/06/2021 10:55PM | Edited 11/06/2021 10:56PM #3
Not sure what you mean by "pictures file" but if you mean you did so while viewing them on your computer that wont work. You actually have to open them for editing then save them (even if they show up correctly in your editor)
Celestron C11
Monroe GA
Posted 11/07/2021 12:56AM #4
Ah, thanks. But if they¿re right side up on my computer do I then open them and invert them?
Posted 11/07/2021 11:28AM #5
No.....you should only have to load them into an editor....if they show correctly then simply save it as if you did make changes. If they dont show correctly then adjust as needed and then save.
Its a weird issue that pops up with photos sometimes for some reason.....Have seen it several times myself and simply loading them into an editor and saving them again even if they load oriented correctly seems to cure the issue.....I read about the cause but dont recall enough about it to explain other than it is something about the hidden metadata? in photos not getting saved correctly.
Celestron C11
Monroe GA
Posted 11/07/2021 08:34PM #6
Thanks!  Stupid computers.  I can re-do my silly pictures. John
Posted 11/07/2021 08:34PM #7
Posted 11/07/2021 09:01PM #8
It works!!  Thanks again
