Wizard Nebula
Where are my sent emails?
Started by SKS, 11/24/2016 11:59PM
Posted 11/24/2016 11:59PM Opening Post
Greetings,
Where do I go to view the emails I have sent to prospective sellers?
I cannot find my sent messages, and I haven't figured out how to have a copy of my sent messages emailed to me either... All that I can find is the inbox to the seller responses... of which there are none. I'm not even sure that they received my inquiry.
Best regards,
Suresh
Suresh Sreenivasan
  - Minnesota Astronomical Society Board Member & Beginner's Group Coordinator
  - Deep Sky, Comet, Planetary & Solar Eclipse Observer Since 1984 / Imaging Novice
- Cassegrains: Vixen 8" f/9 VISAC Modified / Simmons 4.5" f/7
- Dobsonians: Homemade 16" f/4.9 / Orion 12" f/4.9 (Osypowski Aluminum Eq. Platform)
- Maksutov-Cassegrains: Sky-Watcher 7" f/15 / Quantum 4" f/15 / Meade 3.5" f/13.8 ETX
- Newtonians: Criterion RV-6 f/8 / Edmund Astroscan 4" f/4.3 / Orion 3.6" f/13.6 TCT
- Refractors: Sky-Watcher 120mm ED Esprit / Borg 4" f/6.4 ED Apo / Unitron 150 4" f/15 Achro / Jason 60mm f/15 Achro
- Ritchey-Chretien: MallinCam 10" f/8
- Schmidt-Cassegrains:  Celestron 9.25"/8" f/10 / B&L Criterion 4" f/12
- Schmidt-Newtonians:  Meade 6" f/5 / Celestron 5.5" f/3.64
- Solar: Lunt 80mm f/7 Double-Stack
- Binoculars: Vixen Giant 12x80s (Orion Paragon+ Parallel Mount) / Nikon 10x50s
- German Eq. Mounts: Celestron CGX/AVX / Vixen GPDX / Sky-Watcher EQ6R-Pro
Posted 11/25/2016 02:24AM #1
Suresh Sreenivasan said:
Greetings,
Best regards,
Suresh
They would be in your sent mail folder of whatever email program you are using....that has nothing to do with astromart.
Unless of course you meant the astromart private mail system instead of emails. If you did then I don't believe there is a sent folder.... I personally wouldn't be using the PM system to conduct business since you don't have a record of what you sent using PM's
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
