james carter
North American Nebula NGC7000
Best Binoculars for use While Soaking in a Spa
Started by bevbruce, 03/17/2005 02:56AM
Posted 03/17/2005 02:56AM Opening Post
I need some help in selecting a new pair of binoculars. I have a 4" refractor telescope I use when viewing in my backyard. While soaking in my spa, I use a pair of Nikon 10 x 50 binoculars (handheld). They are nice binos, but cheap (running around $150 new and aren't of the highest quality for stargazing).
Soaking in a spa, especially in colder temperatures, poses some fogging/steaming up problems, as well as moisture issues. I like my Nikon 10 x 50s, but they do fog/steam up, the stars aren't real sharp, focussing is limited, and while soaking, especially with the jets running, I have "shake" when holding the binos since I'm really not bracing them and more gently moving in the water.
What I'd like are suggestions as to which binos to invest in for stargazing while soaking in the spa. I was thinking of the Canon 15 x 50 IS binos, but then read some reviews and wasn't sure if this (or any image stabilizing binos) was my best investment for $1000 or so. If spending that much money, would I be better off buying a pair of Zeiss 12 x 56 Victory or Swarovski 15 x 56? Other brands of similar high quality?
My main points are that they should be as fog/steam-proof as possible, watertight or waterproof due to spa water splash, crisp and good focussing for pin-point stars, and strong magnification that can be achieved without a tripod.
Thanks in advance for your suggestions. 8)
Posted 03/17/2005 06:29PM | Edited 03/18/2005 01:51AM #1
In those spa conditions, no binocular is going to be fog proof.
Be very careful about waterproof. That is a loosely used term. In some cases it means only that you can wash off your binoculars under running water. Others will hold out water at a depth of 1m or 2m for a time of 5 to 10 minutes. I would not trust ANY of those criteria if a binocular were dropped in HOT spa water. You should be fine holding it above the water.
Generally 10x is the maximum power for handheld. It varies a lot with the individual. Some people can hold 12x. Some claim to hold 15x and 20x. Don't believe those claims. While I won't dispute some few may be able to hold 15x steady, most would be seeing fireflies.
If you want higher magnification than 10x or 12x handheld, an IS binocular is the only way to go.
You mention Nikon 10x50s. The Nikon Action Extreme 10x50 or 12x50 is a pretty decent WP binocular. The Pentax PCF-WP 10x50 is a better binocular. all sell for between $150 to $189. The Canon 12x36 IS II (the newest model) is being talked about very well and is reported to nearly equal the performance of 50mm binoculars.
edz
