Here is my solution for eliminating neck strain, vibration, and long term comfort. I've made parallelograms, chairs with attached and unattached articulating arms and even bought and modified a dentist's chair at an industrial sale. (my wife called the dudes in white coats)!
It can be mounted on a pier for sitting or standing, or on a table. It's a "Dobino"!!
I don't understand some people's reservations about a reversed view. It's only objectionable if you never try it!
Newts and refractors aren't correct views either.
There is a production model advertised in S&T that I'm sure is fine, although it doesn't appear to rotate in azimuth. If you have a copy of Astronomy, Feb 1997, there's
a step by step article for making the mount just as you see in this photo.
The "arm" is a red dot finder that makes pointing second nature. The mirror is a high quality flat purchased from American Scientific for five dollars.
And NO, the mirror doesn't degrade performance! If a mortal can detect the difference it's only in the mind beforehand.
I've used several binos on this mount. Try it!!
Good times!
John
Good times!
John
