Mark Eby
M33 Triangulum Galaxy
Binocular Illumination Tests Part II: Methodology
Started by Milt, 05/09/2004 02:45AM
Posted 05/09/2004 02:45AM Opening Post
The first test was to slide the laser around the objective to check for on-axis (center of field) illumination. The exit pupil dot should remain stationary in the center of the field during this test. If the dot moves as the laser nears an objective edge, it indicates aberration(s) that will affect the star image. If the dot disappears before the laser reaches an objective edge, it indicates vignetting and less than 100% illumination at the field center.
Once the on-axis work was done, I taped a shim onto the edge of the laser holder to incline it at a known angle relative to the optical axis. I used two shims, one 0.6mm thick including tape, and the other 1.2mm. The spacing between a shim edge and far base edge measured 45mm. This allows the tilt angle to be calculated: arctan(0.6/45)=0.76° for the thinner shim and arctan(1.2/45)=1.53° for the thicker.
An off-axis laser beam shifts the exit pupil dot away from the center of the field. Again, it should remain stationary as the laser is moved around the objective, providing the laser is not rotated while being moved. Knowing the incident angle of the laser and measuring the dot position on the paper allowed me to confirm the TFOV of each binocular.
As I moved the laser over the objective in the direction it was inclined, I found that the dot would disappear before it reached the objective edge, indicating some vignetting of the off-axis beam. However, there was no vignetting at the opposite objective edge and seldom along either perpendicular edge. This makes the lost objective area a crescent, which is difficult (for me) to calculate. To come up with % illumination, I estimated the usable objective area from sketches on graph paper. As a sanity check, if one half of the objective is contributing full illumination and the other more than 50% of its half, we know the total illumination must be better than 75%.
The next picture is of the Canon’s from the top of the table. The red tape marked the edges of the laser base with the beam at the objective edges.
Milt's attachment for post 15739
Posted 05/09/2004 10:52AM #1
There's one big difference in what we intepret as % illumination based on what you described above.
I consider this. If the enlarged full exit pupil I am watching is 30mm round, it's easy to understand it is 100% illuminated.
I believe it is true to say every point in the fully illuminated exit pupil receives light from every point on the objective.
By definition then, I take it as only entering light that produces a fully round exit pupil is contributing to 100% illumination. Any entering light that produces less than 100% round exit pupil is not contributing to 100% illumination.
If entering light causes that exit pupil to vignette, the shape seen is that of a sharply defined pointed ellipse or cats eye. If the size of that cats eye is now 15mm wide by 30mm, it is observed to be one half the width of the original exit pupil. This to me indicates no point in the exit pupil is now fully illuminated.
If light entering is producing an exit pupil 30mm x 15mm cats eye, then light from that portion of the objective is not providing 100% illumination to any point in the exit pupil. In fact if the exit pupil is half normal width, isn't it true no point in the exit pupil is fully illuminated, because no point in the exit pupil can be receiving light from every point on the objective?
Is it incorrect to say that for any point on the objective to provide 100% illumination, it must contribute to a full exit pupil?
edz
