I recently purchased a Bogen Manfrotto #516 Fluid Pan Head. I wanted something that would work well with heavier
payloads and would set up easily. I already had a Bogen 3063 fluid pan head, that head has about a 11 to 12 lb. payload capacity which is a great combination with the 6.6 lb. 20x77 Miyauchi. I have even tried it with the 12 to 13 lb. 20x100 Miyauchi, but that is really pushing it! The 20x100 is normally used with a "Light Speed Wagon mount, previously pictured with my 6" f/5 refractor; it, however, does not set up that quickly. The Bogen 516 mount has a 22 lb. capacity with minimum recommended payloads being 4.4 lbs. and the ideal balanced payload being 16.5 lbs. This mount has adjustable tension and a very hydraulic feel. If tension is released somewhat the head will return to a horizontal neutral position. Loosen it more and it will return faster. Playing with this feature you can actually "track" objects to a certain extent as the head slowly glides to it's neutral position. Jets are real easy and you feel like you are an anti-aircraft gunner.
This pan head sells for about $450 to $500 discount. The next step up from Bogen are heads that top $1000.00. Anyway this head has dual telescoping handles that can be rotated and adjusted to virtually any position. The handles have foam grips at their ends. The mounting plate is a dovetail and it comes with an assortment of mounting screws. The mounting plate is constructed so that a red spring loaded safety bar coming in from the side will prevent it from sliding out all the way if the locking lever is accidently loosened.
The pan head is set up on an old Davis & Sanford tripod via a half pier made from a solid bar of 2.5" diameter aluminum that is 10" long. This bar has 3/8-16 holes tapped into each end. This half pier allows for clearance of the handles and eliminates possible interference from the eyepiece end of either binoculars or a telescope. I am fabricating a circular eyepiece tray that will fit over the 2.5" diameter aluminum half pier. It was originally a 9" heavy aluminum and teflon coated "Martha Stewart" cake pan from K-Mart. (You can say what you want about Martha Stewart, but she sure makes good astronomical accessories!)
The pan head will also work on a Bogen 3036 tripod that I have. That may be the way to go some of the time and will give me the flexibility of the crank up head.
For those not particularly enthralled by parallelogram mounts and especially for those that have an existing tripod that they may be able to modify to work with this head, I believe it can be just what you are looking for with a variety of payloads when alt-azimuth is the way to go.
Bogen Manfrotto 516 Fluid Pan Head - highly recommended!
Barry Simon
Barry Simon
