Bogen tripod help
Started by rmcnelly, 03/27/2004 01:59AM
Posted 03/27/2004 01:59AM Opening Post
I bought a used Bogen 3021. It works great but the center support is a two part assembly which is loose. If I have the tube elevated far enough that the top section is clear of the clamp, the top of the tube will turn when I'm trying to turn the fluid head mounted on top.
I took the allen wrench hidden under the rubber plug on the bottom of the tube, and was able to back out an allen screw to where it will catch the edge of the tube and not allow it to turn. But the top tube moves significantly in a vertical plane when moving the fluid head's elevation. It's very irritating.
Is there some other way to secure the two tubes together in a solid, tight connection?
Rick McNelly
West Point, VA
