Iris Nebula
Canon 15x50 is battery usage
Started by jterry94, 05/31/2006 06:38PM
Posted 05/31/2006 06:38PM Opening Post
Hi All,
I recently purchased a Canon 15 x 50 is binocular. It appears to drain the battery when not in use.
I put in fresh lithium batteries, use if for an hour, and come back the next day to find the batteries drained.
This is a bit of an annoyance. I shut off the IS and it has a 5 minute shut-off feature anyway so I don't know
what could be draining the batteries overnight.
Has anyone else seen this?
Jeff
Posted 05/31/2006 08:29PM #1
No, never heard of that one.
Posted 05/31/2006 08:40PM #2
Have you verified that the IS feature does actually shut itself off?
Clear skies, Alan
Posted 06/07/2006 09:27PM | Edited 06/07/2006 09:29PM #3
Jeff Terry said:
Hi All,
Jeff
Hi Jeff,
My apologies for taking so long to respond. I had to find a Canon 15x50IS to check, etc.
If you have not already sent them back, do so. I can confirm that the pair I tested have no battery drain when switched off either manually or through the automatic shutoff. The electronic meter I attached to check current drain actually draws more power to take a reading than the Binoculars themselves in the "Off" mode.
You definitely have some kind of issue with either the Binoculars or a bad battery pack. Either way, since they're new, you shouldn't have a problem getting the issue resolved.
Clear Skies, Bill
