Wizard Nebula
Illumination Tests Results
Started by Milt, 05/09/2004 03:06AM
Posted 05/09/2004 03:06AM Opening Post
I tested three binoculars:
1) Early 1960's Ofuna Kogaku (Tower) 7x50
The on-axis (field center) tested 100% illuminated, but the exit dot moved significantly as the laser approached the objective edges, indicating aberrations. The TFOV measured slightly larger than the claimed 7.1°.
The 0.76° shim (21% from field center to edge) caused 3mm max. vignetting along only one edge. The 1.53° shim (43% from center) caused 6mm max. vignetting along one edge and less than 1mm along the perpendicular edges. Estimated illuminations 94% and 87% respectively.
2) Canon 18x50IS, IS turned off
The on-axis (field center) tested 100% illuminated and the exit dot had much smaller movement than the Ofuna's as the laser approached the objective edges. The TFOV was about 3.5°, as advertised.
This binocular has some strange goings-on inside. Non-symmetrical vignetting dependant on the orientation of the incident angle was observed with both shims. Also, in two orientations illumination was actually regained in the direction opposite the vignetted side. This made it very difficult to estimate illuminations, but here goes: for 0.76° off-axis (43% from center), 91% and for 1.53° off-axis (87% from center), 80%.
Here is a picture of a Canon 1.53° off-axis dot with the laser positioned just inside a perpendicular objective edge. The drawn circle has a 3° diameter.
Milt's attachment for post 15741
