Mark Eby
M33 Triangulum Galaxy
Markus, Any Luck With Kowa?
Started by Milt, 12/21/2002 05:58PM
Posted 12/21/2002 05:58PM Opening Post
Hi Markus,
I am following up on your quest to get Kowa to increase the power on the Highlander.
You have probably already thought of this, but rather than asking them to modify the focusers, do you think they could do an adapter with a male end the same as their EP's and a female end designed to take standard 1-1/4" EP's?
Because this would move the EP further away from the body, a negative correction lens would be required in the adapter to achieve focus. However, any increase in power would not be a problem because this is what you are looking for anyway. (Kowa already has the low power end nicely covered with the 21x 3deg. EP)
What do you think? These types of suggestions probably carry more weight when coming from a dealer.
George, if you are reading, have you received your Highlanders yet?
Merry Christmas, Milt
Posted 12/22/2002 03:05AM #1
Hi Milt,
I have received the Kowa's and two sets of eyepieces, waiting for the 50's to be shipped in about 2 weeks or so.
I just got the Universal Astronomics Millennium mount yesterday and used it last night. We have had peasoup for sky here since I got the Highlanders 2 weeks ago. I used the Highlanders once before last night with a Bogen 3233 tripod and a 3063 video head I normally use with the Fujinons and a mirror mount. The mirror allows full access to the sky with this setup and the Fujinons. The setup handled the Highlanders easily and the quick release made it quick and easy but the altitude was limited. Last night was the first night I could really use these because of the UA mount and of course the moon was full, good that the sky was exceptionally clear.
I use a JMI NGT-6, a Questar 3.5 duplex with zerodur and bb coatings and Fujinon 16x70, Steiner 10x50. I have a limited amount of equipment and no large aperture pieces.
I do not have other large binos to compare the Kowa's to.
I am extremely impressed with the Kowas, the contrast is most similar to the NGT-6 which has an excellent mirror which I use with an assortment of televue eyepieces from 30mm to the 3mm-6mm radian zoom.
With the Highlanders at 32x, Andromeda, the Pleiades, the Orion Nebula with the trapezimum and very green nebulosity and defined borders and shades, numerous star clusters... were all amazing. Sirius was a large perfectly white sphere. Even the full moon was very fantastic. They may look this way in all larger binos, have no benchmark. Ater having high expectations because of Markus' review, I was not disappointed. I am looking forward to a dark sky site 30 minutes away to really find out what the Highlanders are capable of.
The Universal Astronomics Millinneum mount made these a pleasure to use, it is if they are floating in space and you simply point them where you like with ease, change from standing to sitting without any fuss. I would prefer a lighter mount but the tradeoff is worth it. Setup and breakdown is a breeze and quick. Setup the tripod, slip on the mount and slide the binos on.--breakdown is just as quick.
My wife came out and all I got was a series of wows and laughs as she began to SEE why I go outside in the dark.
She did say "I like these better than your telescopes" as she retreated. She did a little exploring with them and would then look up at the sky and ask "Where are all those stars?".
The images and contrast made these a real pleasure to use.
The various colors of the stars were a pleasure. I can clearly see things the Fujinon's only hint at as would be expected. Reminds me of going from 10x50 to the 16x70 but even more of an improvement. This is obviously no comparison of the Highlander's to similar products and I admit I am unable to do so at this time--these sure are fun to play with.
Merry Christmas,
George
Posted 12/24/2002 01:15PM #2
Kowa is slowly and not yet send me any adapters, sorry
Markus
clear skies
Markus Ludes
APM-Telescopes/Germany
