Wizard Nebula
Solar observing with binoculars
Started by mirfak, 01/14/2014 10:20PM
Posted 01/14/2014 10:20PM Opening Post
Hello
First, please use extreme caution when observing the sun!
I was finally able to complete two solar filters for my binos using Baader solar film. Back on November 3rd I was able to monoview the solar eclipse using a filter from my old telescope. Two eyes are better than one, so I knew I had to make filters for both objectives.
I started with the round paper boxes found in craft stores. They served well in the past. I found ones that fit over the objective, but didn't fit the tube. Lets start again.
The bino objective covers screw on with 95mm threads same as camera filters. Why not use this feature to my advantage? I tried 95mm filter rings, but they didn't grip the thin film. I ended up adding 95-105mm step up rings and used 105mm filter rings to hold the film, sandwiched between two washers made of cardstock.
Cutting a clean circle into the paper was tricky. I wanted to use the full 82mm of aperture, but make the washers wide enough to hold the film securely. The central aperture of the paper is a little eccentric, but still allows full aperture.
The final assembly is secure and compact. Wind and curious hands wont pull the filters off.
I tested them yesterday. The big active region with giant sunspot was visible on the western limb. There were about a dozen other spots of various sizes. The detail was amazing. Penumbra detail , faculae along the limb, and granulation all over the surface. Not bad for a small aperture.
I'm tempted to give up my telescopes and just use the binos.
Thanks
John
mirfak's attachment for post 58120
Posted 01/14/2014 10:22PM #1
Another photo showing one solar filter attached.
mirfak's attachment for post 148068
