VDB 142 Elephant Trunk HOO
What size max pupil?
Started by light trap, 07/23/2003 07:32PM
Posted 07/23/2003 07:32PM Opening Post
I've written before about the perils of assuming that one's own pupil is magically transformed to 5mm max at age 50 (or 40, depending on which source is cited. This chart of 1263 measured individuals may shed some light on the extreme range of max human pupil dilation.
http://f1.grp.yahoofs.com/v1/MNseP0ifWCCMyrEiC0BGBigSJTe53aqDXCJ7c6qRTT4d4ubJz1lQrVFSaBNcXHrXSyVoW-uHX4tx4AlT/Pupil.jpg
You may have to copy and paste that rather long link back together. Note that not only are there individuals at 60 & even 75 with near 7mm max pupils, but also note the incredible range of the 15year olds, and the general spread. Sure, there is a very definite downward trend, with most grouped in the middle, but it looks like a lot of folks may tend more towards 6mm well into their 60s. I thought that chart was pretty interesting. Guess it just goes to show that there's no substitute for measuring one's own pupils.
Mike Swaim
Posted 07/23/2003 11:17PM #1
I extracted that from Mel Bartel's excellent treatise on rich field telescope viewing. He linked to it from there.
So, go to this site, then either read the whole article (highly, highly recommended), or just go to a section titled, "OK, So Increasing the Magnification Doesn't Work-- How About Decreasing the Mag?" then click on the first hyper link
http://www.efn.org/~mbartels/tm/rft.html
There are very clear median lines that could be drawn from that chart.
roughly 6.5mm max pupil from age 20 to age 40
roughly 5.5mm max pupil from age 40-65
roughly 4.5mm max pupil from age 65-75
But the thing of it is, to get those median lines, one has to average folks that are WELL outside those ranges at every point. So, my point is to suggest that unless you know for a fact that your max pupil is X, then it's perhaps not terribly kind to yourself to assume limitations or abilities that you may or may not actually possess.
Making matters worse, is the whole idea that best acuity is never at max pupil dilation, but rather something smaller to get away from the natural abberations at the edge of the pupil. The question then becomes, how much to reduce exit pupil from personal max? That question is addressed in some form in the Mel Bartel article.
Mike Swaim
