15mm Pans Update
Started by tomhole, 04/16/2004 04:00AM
Posted 04/16/2004 04:00AM Opening Post
Short answer: they are light robbers. I compared them to my 13mm type 6 Naglers on Jupiter and Saturn and the 13T6's are discernably brighter. That ain't right. The higher mag should be dimmer. I attribute that to the excellent transmission of the type 6 and the less than stellar transmission of the 15 Pan. The 13 Nagler is also sharper, but I can't negate the extra mag as a contributor here. The 15 Pan definitely delivers a warm image.
10mm eye relief is too tight as well. So, they've gotta go. That might eliminate the 16 type 5, unless I just give up the extra AFOV. How's the comfort of the 15mm TV plossl or Ultima/Ultrascopic? 15-16mm is my most used mag (240-250x)
Clear skies,
Tom
