There is more than cost to consider when contemplating the purchase of a 2" binoviewer. You should also consider weight.
The standard 1 1/4" Black Night binoviewer with diopters weigh 22.2 Oz. The 45mm Elites with diopters weigh 35.4 Oz.
Since an SCT needs no OCA to get either of these units to work, lets say we decide to use a pair of 26mm EPs in our SCT. If we are going with 1 1/4" Black Nights(22.2) and a pair of Meade Super Plossls (8.4) we have a total weight of 30.6 Oz. at the end of out telescope.
If we go with the 2" 45mm Elites(35.4) and a pair of Celestron E-LUX 2" 26mm(23.2) we now have a total weight of 58.6 Ox. on the end of our telescope.
I also checked my Nagler 12mm Type 2 Eyepieces. The pair of them weighed in at 34.2 Oz. To protect the optical window at the base of the eyepiece holder when using these or other eyepieces that fit both 1 1/4" & 2" holders you should add in the weight of an adapter. Sieberts has some nice ones that only weigh 1.5 Oz. each. That makes the total for the 12mm T2 Naglers, adapters, and 2" 45mm Elites a hefty 72.6 Oz.
I also had some lighter weight and less expensive eyepieces made by Gary Russell. The pair of 19mm SWA Konigs weigh 10.6 Oz. and my 16.8mm SWA Konigs weigh 10.2 Oz. I will say that I have been happy enough with these EPs that I contacted Gary and ordered a pair of 11mm and 22mm EPs from him. He is going to match them for binoviewing for me. At less than half the weight of the E_LUX and a third the weight of the Naglers, these EPs are something to consider. The price is also very reasonable.
You are probably going to have a diagonal on the back of your SCT anyway, but, I was in a weighing mode. I checked 4 different brands of 2" diagonals I had on hand. I found my William Optics diagonal had a weight of 14.4 Oz. and was the lightest diagonal I checked. The Antares 2" diagonal weighed 18.4 Oz. and was the heaviest I had. A standard Meade 2" diagonal weighed 16.4 and a Generic Japanese no name weighed in at 16.8 Oz.
When using the 45mm Elites the other night I found that my C9.25 tracked very well on my SkyView Pro Mount. I also do not expect any trouble with my Meade 152ED on my LXD-750 mount.
I am not trying to scare anyone out of buying a 2" binoviewer, I am just trying to get some numbers out there so you can make an informed decision.
Don Durbin
