Well so far I can say that I am very pleased with the 45 Elites. As you can see from the image, I have a Williams Optic crayford focuser with a Williams Optic 2" diagonal. When you add in the 45mm Elites that is an awful lot of extra length but the Celestron 9.25 can still focus.
I was beginning to think it would be another wasted night when I got a peek at the moon. Once I started tracking it I was able to keep viewing without too much problem.
It did actually clear off for a short period. The clouds have rolled back in now. I am hoping for a look at M42 later tonight.
The detail through the 45mm Elites is amazing. Near the south pole of the Moon is a peak that is almost always in light. It looks like a little light house because it sticks up out of the dark terminator. I always look for that. Below the light house there are a few medium sized craters. I know they all have names and I do not know which is which. In one of the craters I could see some small impact craters with the 45 Elites. When I pulled out the binoviewer and put in a single eyepiece I could not see them. Switching back to the binoviewer the small craterlets where still apparent. I did this 3 or 4 times. I could definitely see more detail with the binoviewers. It must be the increased size that a binoview gives you. A binoviewer cannot give you any more resolution over a single eyepiece. However, after this experiment, I can definitely say I cannot see where I am loosing any resolution with the binoviewer.
My Orion 32mm Optiluxe eyepieces were a little disappointing. They have a kidney bean effect that seems a little worse with the binoviewer. I could use them but I had to hold the tops of the eyepieces and touch my forehead to maintain the perfect distance. The older shorter Orion Optiuxe eyepieces do not seem to have as much of a problem as the newer ones. I have one 40mm and one 32mm of the older type. I like them much better. I even put them both in at once and I was able to merge the images. How weird is that??? It is not something that I would recommend for extended viewing.
The Clouds are clearing off again. Hopefully I will get my view of M42 tonight.
Don
Don
