Greetings Friends,
I have a problem with viewing through my burgess binoviewer, and seek your indulgence in figuring out a solution.
I am using a Burgess binoviewer with 1.9x Burgess OCA (along with 1.5 inch extenstion tube) with 20mm bino-lite eyepieces on a f5 8 inch dob.
My problem that is stars are not pin-point; I have enough in-focus because I can focus in and out..the stars (for example albeiro) look like sea-gulls..with flaring off to one side.
I don’t think it’s a scope or eyepiece problem because the same eyepieces work great in Cyclops mode (with and without a 2x Barlow – alberio stars are pin point).
Interestingly, the same binoviewer-eyepiece combination works well with my 4.5 inch f8 dob. This makes me wonder whether 1) the binoviewer is slight mis-collimated – with the f8 scope forgiving of miscollimation errors, while the f5 system is more stringent; or 2) the ¼ optics of inexpensive prism accommodates the F8 light cone but not the F5.
I tried using 32mm eyepieces with the binoviewer on the f5 dob, in this situation the stars are not sea-gulls – not exactly pin-point..but certainly more bearable.
BUT, the very small FOV, mag is low, and vignetting is a little bothersome.
Right now, I use the binoviewers with my 4.5 inch, but cannot view anything else other than the moon (which remains an awesome experience..EVERY SINGLE TIME I USE IT!)
I wish to get your advice over which of the following would be the correct solution;
1) Purchase a seibert 1.25x OCA with the hope that (based on my 32mm eyepiece experience) the lower magnification will make it easier to view stars
2) Upgrade the f5 to an f8 8 inch dob (too expensive)
3) Buy another binoviewer and hope that might work with my scope. (too expensive)
4) Get the binoviewer collimated (assuming its possible to do so, and the cost is reasonable)
Therefore, based on your experience, may I request your advice on what would be the best course of action?
Thank you very much for your time,
Kumar Pandya
Kumar Pandya
