Binoviewers and Refractors
Started by DonDurbin, 11/29/2004 03:46PM
Posted 11/29/2004 03:46PM | Edited 11/29/2004 03:49PM Opening Post
Some of us are aware of the ability to reach focus with a binoviewer without the use of an OCA/OCS and diagonal. The binoviewer is inserted directly into the refractors visual back. This is only possible with some refractors. My Stellarvue AT1010 will reach focus with a 1/4" to spare for terrestrial viewing when using my original Black Night binoviewers. Focusing on Astronomical object requires more in travel and will not work even with the short length of the original Black Nights. I could not reach focus on terrestrial objects using the 45mm Elites with this method.
I used the same 1 1/4 eyepieces in the 45mm Elites as I used in the original Black Nights for these tests.
If I add in a diagonal and place an UltraBarlow on the binoviewer,(This is similar to a powermate in design) I can focus on terrestrial objects with the original Black Nights with an 1/8" of in-travel to spare. The 45mm Elites still do not reach focus.
If I place the UltraBarlow directly into the telescope and then add the diagonal, both the original Black Nights and the 45mm Elites come to focus at the end of the focusers travel. A Stellarvue AT1010 focuser has 4 inches of travel. At least that is what I measured on mine. Since Astronomical objects require more in-travel this arrangement will work for planetary and deep space viewing.
Interestingly if I use a two inch extension in back of the UltraBarlow before the diagonal it does not change the point of focus on either the original Black Night or the 45mm Elites. If I place the two inch extension first followed by the UltraBarlow and then the diagonal I end up with the terrestrial focus point for both the original Black Night or the 45mm Elites a full 2" in or dead center in my focusers range.
Another very good reason to place a barlow or powermate before the diagonal is that it puts less stress on the diagonal and less weight on the extended moment arm.
I am sure I am not the only person who has seen a diagonal or the visual back on the scope slip or unscrew and watched as my binoviewers and eyepieces flipped upside down. Not a good thing to see on a full stomach. cwy
In my next post I will add the Sieberts focal reducers into the mix. I need to go out and buy a pair of yard sticks so I can show magnification factors.
DonDurbin's attachment for post 20472
Posted 11/29/2004 05:10PM | Edited 11/29/2004 08:33PM #1
Don,
Thanks for the report. Is it cold up there in OH?
I am interested in the magnifications you measure. I know the 2.5x Powermate magnification actually decreases the further you get from the design point (it is 2x as a corrector). The 2x Powermate stays fairly constant and the 5x Powermate mag increases as you move further out (it's about 7.5x as a corrector).
I haven't weighed my BB's yet. I forgot to this morning. I imagine they are the same weight as the BC&F Binomates and those weigh 17.5 ozs, but I'll weigh them tonight.
Tom
