Burgess Binoviewer
Started by mikelst, 01/17/2005 12:19PM
Posted 01/17/2005 12:19PM Opening Post
The specs listen on the ANACORTES sight
http://www.buytelescopes.com/product.asp?t=&pid=8211&m=
list the ca at 24mm. does anybody know anything about this?
Is it for real...
Thanks
Mike
Posted 01/17/2005 02:25PM #1
Well, not really. The clear aperture at the nose is 24mm. The beamsplitter clear aperture is 22mm. But there is a baffle at the base of the ep holders that acts as a field stop and limts the actual clear aperture to 17-18mm. That is what I would use to compare the current BB's. That means a 20mm plossl will not vignette noticably, but a 32mm plossl will vignette badly (probably down to a 32 deg AFOV or less).
The BB's are good binoviewers, regardless of price, but a great value if you include price. I would buy them over the BC&F as they are 1. cheaper 2. include a decent pair of ep's and 3. use better prisms. For $200, I'm not sure you could go wrong.
The lack of a low power corrector will frustrate you if you are using a refractor or dob. Harry Siebert has a low power corrector that will work and I would recommend considering one. With the limitation on widefield ep's, getting a low power corrector is important. As much as I enjoy planetary viewing with my binoviewers, widefield is even better.
Hope that helps.
Tom
Posted 01/17/2005 02:26PM #2
The Anscortes information is not correct.
Read the specs on the Burgess site. They say 18.5mm. Most ads say 18mm.
http://knightcontrol.freeservers.com/BO_Accs_Binoview.htm
Don Durbin
Posted 02/04/2005 09:19PM #3
The Highpoint Scientific website lists the current model as the BV-125 "C" and says that this model has 22 mm of apeture, but notes that since the beamsplitter is also 22 mm, some "clipping" may occur.
Has anyone heard from Bill lately about whether there is indeed a "C" model which does away within the constriction from the internal baffle?
Also noted on the Highpoint website that although the Burgess Binos still use set screws (instead of constricting bands), this supposed "C" model now uses 3 instead of just 1, and they are all nylon.
Looks like some decent improvements if they prove true.
Bill, please tell us if this is the real deal.
JK Edwards
Clear Skies,
Joe
Nexstar 8i
6" f/8 Dob
Orion ST80
Binos: 7x35, 10x50, 11x70
