To All,
My Burgess binoviewer arrived today. It was delivered a full day early. Naturally we have a heavy overcast tonight with fog.
The unit arrived with a note saying it was a BV125 Model 'C'. This model has three thumb screws in each holder spaced 120 degrees apart. The unit arrived with a pair of 20mm Eyepieces. Looking into the unit and comparing it to my 22mm BlackNight binoviewer, it looks like this unit has a 22mm clear aperture. The diopter adjustments seem a little stiff and do not have as much travel as the Diopters on my BlackNights. They are however fully captured, something I wish my BlackNight diopters were. They are also standard equipment on the Burgess where the diopters on the BlackNights are optional.
I did try the unit out on a neighbors small satellite about three or four hundred yards away. The images merged easily in the supplied 20mm eyepieces. I was using a Sieberts 1.3X OCA with my Celestron 102mm Wide View refractor and a 1 1/4" Lumicon Lumibrite diagonal. I popped in a pair of 18mm Radians and found I was quite please with the image.
I plan to do Tom Holes Clear Aperture Solar test and I also plan a head to head test between my 22mm BlackNights and this unit when the weather improves.
Don Durbin
Burgess BV125 model 'C'
Original 22mm BlackNights with Diopters
45mm Elite BlackNights with Diopters
Sieberts 1.3X OCA, Sieberts UltraBarlow, Sieberts Multimag OCA.
Denkmeier 2" SCT Star Diagonal
Stellarvue AT1010
Meade ETX90
Stellarvue 102APO
Celestron C9.25
Orion Atlas 8"
Meade 152ED
Don Durbin
Stellarvue AT1010
Meade ETX90
Stellarvue 102APO
Celestron C9.25
Orion Atlas 8"
Meade 152ED
