Ruben Tommasi
Andromeda Galaxy (M31)
Denk 1.25" 2X multiplier
Started by Brian Goodman, 04/09/2004 03:30AM
Posted 04/09/2004 03:30AM Opening Post
For a Refractor, does that just screw on part S, or do you remove part S first?. And then that will double your magnification in 1.2X mode and 2.5X mode?... thanks.
Posted 04/09/2004 12:10PM #1
Brian,
Part S screws onto the nose piece. The 2x Multiplier screws onto the filter side of your diagonal. If you have a 2" diagonal you also require Part T adapter. For higher power, remove Part S from the nose piece. I am not certain what the power factors are. I think it is 1.4 using Part S and 2.8 without but I am not positive.
