Focus Problems with Burgess Binoviewers
Started by denniris, 02/12/2005 04:22AM
Posted 02/12/2005 04:22AM Opening Post
I am using a Celestron 102GT (500mm f5) with 2" diagonal. I received this scope today with my Burgess Bino, My plan was to install drive on a good sturdy tripod and at some point replace the OTA with a short tube APO. In playing around with this set up I found I could not rack the focuser in far enough to achieve focus with the binos with or without a 2X Barlow. I had expected problems with out the Barlow but not with. With out the Barlow the BBs almost come in to focus just as I run out of in travel and adding the Barlow just seams to make it worse. Is the Burgess 1.5X Relay Lens going to solve this type problem or should I go with my first thought which was to shorten the Optical Tube by 1.5" ?
Any input would be appreciated.
Dennis White
Posted 02/12/2005 05:57AM #1
Dennis,
Try putting the Barlow directly into the telescope and putting a diagonal into the Barlow. Then insert the binoviewer into the diagonal. This should allow you to focus.
Don Durbin
Denk IIs coming UPS
Burgess BV125 Model C
Original 22mm BlackNights with Diopters
45mm Elite BlackNights with Diopters
Sieberts 1.3X OCA, Sieberts UltraBarlow, Sieberts Multimag OCA.
Denkmeier 2" SCT Star Diagonal
Stellarvue AT1010
Meade ETX90
Stellarvue 102APO
Celestron C9.25
Orion Atlas 8"
Meade 152ED
