Iris Nebula
Get out and look at Jupiter
Started by tomhole, 01/10/2004 06:35AM
Posted 01/10/2004 06:35AM Opening Post
If you're on the east coast and have some long johns, get out and have a peek at Jupiter. It is very good and the GRS is just starting to transit. Man it's cold.
Clear skies,
Tom
Posted 01/10/2004 07:22AM #1
I know how you feel, Eurvin. Vote with your wallet. Can you email me offline? tomhole at gmpexpress dot net I'd like to chat about the military. Or we can go to the off topic forum.
Clear skies,
Tom
Posted 01/10/2004 07:52AM #2
Well, that was another wonderful (allbeit very cold) morning with Jupiter. During the moments of better seeing, the resolution was easily sub arcsec. Here are some quick observations:
The GRS is more red this year. Another fellow had mentioned this on another group and this was my first opportunity to check it out since he mentioned it. It is not salmon this year.
There is a tiny dot of some sort right over the GRS. I estimate it to be about .5 arcsec or so in diameter. It was not a shadow transit as there was not one going on and it was too small. Anyone seen this?
I found out something very peculiar. I put the Denk 2" OCS in 2.5x mode on the TV binovues and the TV 2x corrector on the Denks. I wanted to check this configuration before making a final determination on which to keep. Here's the peculiar part. Whichever binoviewer had the 2x corrector on it, the image of Jupiter was not as bright. I had noticed this earlier in the evening when the pieces parts were mated with their own brand. I wanted to see what happened when I swapped correctors. Sure enough, whichever binoviewr had the 2x corrector on it had a dimmer image. I checked for dew, frost, dirt, anything that might cause this. Found nothing. This doesn't seem right.
I can say that the best views were with whichever binoviewer had the 2" OCS in 2.5x mode on it. Seeing was 4-5 most of the time with moments of 8-9 (.5 arcsec). I was using my new observing chair so I spent a lot of time looking at detail inside the GRS and the bands. The best view of the morning was with the TV's and the 2.5x 2" OCS, but that may have just been the seeing at that moment. Regardless, they are both extraordinary binoviewers.
The seeing went to crap at about 0230, so I'm packing it in until morning for the transit of Io.
So, to answer Jeff's question about a direct comparison between the TV and Denk stds, my opinion is they are pert near equals. The 2x TV corrector is better than the 2" OCS in 1.4x mode on planets, but the 2" OCS in 2.5x mode is better than the 2x corrector on planets. Both binoviewers appear to put up very similar planetary images with the 2.5x 2" OCS. By similar, I mean similarly exquisite, with fine low contrast detail that will take your breath away.
Another thing I have figured out over the past few months with the Starmaster is that a Zambuto mirror is worth every penny you pay for it.
Clear skies,
Tom
