My experience with the Black Night BV
Started by scotthess, 11/27/2003 04:54PM
Posted 11/27/2003 04:54PM Opening Post
I am using the BN BV in my 10" SCT F6.3 along with the first generation 19mm TV Wide Fields which have 65 AFOV. Without any correctors they provide a mag of 100X. The field stops are crisp. The view through each eyepeice is identical to me in color and brightness.
To achieve enough in-focus I had to obtain an 1 1/4" diagonal and shorten the visual back about 1/4".
The most pleasing benefit of using the BV is the increased contrast from spliting the light in half which effectively reduces skyglow by darkening the background.
To obtain a lower mag Harry made a .7 focal reducer which reduces the mag of the TV 19mm's down to what I believe to be 70X. However, in order to achieve this I needed to make further modifications the scopes in-focus travel by removing the primary mirror assembly and slotting the front of the slider tube by 5/8" to allow the mirror to move forward where to set screw stop is. This was easy to do with a dremel and cordless drill.
Overall I am delighted with the Black Nights as they work perfectly, are relatively lightweight and compact. Harry was very helpful in making sure the BV would achieve the results I wanted in my F6.3 scope by discussing the in-focus requirements and exchanging varous corrector combinations throught the mail.
I am considering purchasing 13mm TV Nagler T-6's with the money I saved from sacrificing 4mm of aparture.
Posted 11/30/2003 07:12AM #1
Scott, you got good results in a unique set up. Sounds like a lot of trouble to go through, though. Would these BVs be useful for the mechanically disinclined?
Robert Howe
Robert Howe
Wilbraham MA
TeleVue 85 f/7 // Astro-Physics Traveler 105 f/6 // Astro-Physics 130 f/8.35
Coronado 60 DS
"Scopes, Brains and Wisdom--but no Beauty"
