Jay Messeroff
Lunar & Solar Transits
New Fashion Goggles
Started by tomhole, 03/28/2004 03:10AM
Posted 03/28/2004 03:10AM Opening Post
I have been having trouble with the local porch lights lately causing reflections in my binoviewer ep's. I also made it worse by removing the eyecups from all my ep's so that they were more comfortable to use. I have tried the shroud thing a few times with ok results, but it's always a pain getting it over my head and it tends to trap the warm breath under there and fog things up.
So, I tried something different. I took my shop safety goggles and removed the plastic lens. Then I used black duct tape to cover the sides. That didn't work as well as I had hoped, so I wrapped some black stuff around them and formed a sort of tunnel. This seems to work great. My nose is outside the shroud (and mouth) so all my breath is kept outside and I haven't seen any fogging tendancies yet.
I used it for the first moon transit and it helped a lot. I was able to use the 13 Naglers T6's for 305x and was treated to a spectacular transit, especially as Calisto moved off the planets rim.
So, whadya think? Were the neighbor kids justified in their ridicule? I think so, but form follows function.
Clear skies,
TOm
tomhole's attachment for post 14482
Posted 03/28/2004 03:38AM #1
You look kinda cute, Tom. The goggles look good on you!
Walter Locke
"The Fearless Spectator"
There are 10^11 stars in the galaxy. That used to be a huge number. But it's only a hundred billion. It's less than the national deficit! We used to call them astronomical numbers. Now we should call them economical numbers.
Richard Feynman
US educator & physicist (1918 - 1988)
Posted 03/29/2004 05:48PM #2
Tom,
I think you are really on to something! I commented here (or on some other BV forum some time ago) that we needed something like horse blinders to block out that stray light. Not only does this mask you rigged up solve that, it also solves the problem with breathing fogging up the eyepiece. I'll be working up something like this to use myself. The cloth may find itself back in a box once again! (poor little cloth...)
Another problem I face up north when it is cold out is the eyepiece getting fogged up from the heat radiating from my eyeballs. Believe it or not, one thing I will try to incorporate is a small fan to keep air moving through the goggles so nothing affects the eyepiece. To push or pull air? That's the question. Maybe the fan will be mounted on the scope. Should be a fun project to see how much airflow is needed to solve the problem (and just how much airflow my eyes can tolerate).
Regards,
Matthew Sherman
Posted 03/29/2004 06:44PM #3
Great idea - who cares what you looks like if it works....
(You *are* already married, right? )
Tom T.
