Ruben Tommasi
Andromeda Galaxy (M31)
Next EP for Baader Bino?
Started by HowardP, 09/30/2004 04:07AM
Posted 09/30/2004 04:07AM Opening Post
I have a giant Baader and use the 2.6 corrector with 16mm Naglers. In my 6" refractor the views of Saturn are stunning.
I would like to have a set of higher magnification pieces (the 16mm give about 180x). I was thinking of getting a pair of 11mm naglers for 256x.
I used the baader on the moon the other night and a pair of 32 meade plossls gave a nice crisp and powder white view. When I used the 16 naglers the powder white image had darkened and was slightly brown. I could also start to see floaters.
Would the 11mm naglers be the way to go or should I consider another EP for crisp lunar, solar, and planet viewing????
I use an alt-azmth mount and the wide FOV of the nagler is usefull.
any suggestions would be appreciated.
thanks howard
Posted 09/30/2004 05:56AM #1
Howard,
I have been using 9mm Nagler T6's for 231x on my Baader and they look white to me although I haven't done a back-to-back comparison with plossls. You would expect the image to darken when doubling the power.
Although floaters are much less intrusive when using both eyes, they still will become more apparent as you reduce the exit pupil diameter. You are already below 1mm at 180x and would be about 0.6mm at 250x. When using high powers I periodically shut one eye at a time to make sure both are properly aligned on the exit pupils. Also, the diopter adjustment becomes more critical at higher powers.
I agree that the additional FOV is worthwhile in a non-tracking setup.
Clear skies, Milt
