I put this same post in the eyepiece forum.
In an effort to get true data, I did the drift test on my 24.5's and 15's in the Denk II. Some of it is surprising.
12.5 f/6 Homebuilt Dob. (True FL 1889mm)
Meade 24.5 SWA, 61 AFOV
Power Switch FOV MAGN.
Low 1.1X .64 95X
Med 1.5X .46 133X
High 1.9X .38 161X
Expanse 15mm, 66 AFOV
Low 1.1X .44 150X
Med 1.8X .29 228X
High 2X .25 264X
I've been tormented over how to eek out more power (Multiplier, another set of eyepieces, a second power switch), and I totally forgot to try the 2" Big Barlow in conjunction with the 24.5's (the 15's were WAY too much power). In a previous thread, someone had calculated that the barlow yielded 4.3X, 5.78X, and 7.3X with the Power Switch. The following data, again using the drift test, is the overall magnification, including the power switch and barlow. The following totals are less than the 4.3X, etc.
Meade 24.5 SWA, 61 AFOV with Televue 2" Big Barlow (2X)
Low 3.51X .2 305X
Med 4.4X .16 381x
High 5X .14 436X
These calculation are, of course, the best I could manage, so I'm sure there's some error in there, but it gets me closer than just using the manufactuer data. The image degradation using the barlow at 305X and 381X was very small, and considering it wasn't a great night and I had just hauled the scope out of the garage, the scope still had not cooled down at all. So the images in the barlow theoretically should be fine under normal observing conditions. 305X should the image of Jupiter that I had been looking for in apparent size.
And if I ever need to get a wider view, I'll just haul out the holy hand-grenade, my 35 Pan!
Clear Skies, Guy
Low 1.1X .64 95X
Med 1.5X .46 133X
High 1.9X .38 161X
Low 1.1X .44 150X
Med 1.8X .29 228X
High 2X .25 264X
Low 3.51X .2 305X
Med 4.4X .16 381x
High 5X .14 436X
Clear Skies, Guy
Denk II w/nags junkie
