question from a Pronto owner
Started by sunistar, 03/09/2009 12:30PM
Posted 03/09/2009 12:30PM Opening Post
I have a Televue Pronto that I hardly use since purchasing my Canon 10x42 IS binoculars. My question is this: is it pointless to get a binoviewer for the Pronto, given its relatively small aperture? I wouldn't ever have a need to pump the power above 40x, which would mean using a pair of, e.g. 12x Radians. Any thoughts appreciated!
Posted 03/09/2009 02:10PM #1
Small aperture scopes make great terrestrial viewers. A lot of refractors will focus a binoviewer when the diagonal is removed from the light path. To see if your scope will work in this manner, focus one of the EP's you plan to use without a diagonal and then measure the amount of in-travel you have remaining. You need a little more than 100mm for a Burgess or other Chinese make. (Orion, WO, Stellarvue, etc.) You need a little over 115mm for a Denk (Remember to remove any PowerSwitch.) A Siebert needs 120mm and a Televue needs 130mm. This is assuming you do not have an OCA or OCS. With a corrector you can probably use a diagonal. Consult the binoviewer manufacturer for more details.
Using the scope without a diagonal can be a real pain in the neck if you are viewing the night sky, but it is a natural for terrestrial viewing if you have the scope at eye height.
For Planets and other near Earth objects a small aperture telescope can give pleasing views. This is especially true for bright objects. The small light grasp of the scope coupled with the light loss through the binoviewer can help bring out subtle detail in a bright object. (Venus, Saturn, Jupiter, and Mars on a close approach.) There is also the two eye binoviewer effect that appears to increase the size of the image by about 30%.
Of course this is assuming you have an optical corrector for your binoviewer or your scope can focus the binoviewer without one. Most all SCT's and even some refractors can do this. (My TAK FS-128 can focus all but the Televue.) Also remember that different EP's focus at different points. You want the EP's that focus the furthest out for binoviewing without an optical corrector.
I have also modified both an SN-8 and an SN-10 with a low profile focusers to use with my Burgess binoviewers without an optical corrector.
Don Durbin
