What Do I Need?
Started by larryinca, 06/11/2005 12:32AM
Posted 06/11/2005 12:32AM Opening Post
Thinking about getting the Burgess binoviewer. What do I need to make them work in my XT10i?
Larry
Posted 06/11/2005 01:36AM #1
Larry,
An XT10 does not have the range of focus to use the Burgess binoviewers by themselves. You will need an Optical Corrector or at the very least a Barlow. A Barlow by itself will result in a very high magnification factor. This is because the eyepieces are located so far from the Barlow lens. A Burgess binoviewer has a light path of 100mm. A combination of a Barlow and a focal reducer will work. The quality will be hit or miss.
A while back I posted a message on how to make your own OCA.
https://www.astromart.com/forums/viewpost.asp?forum_post_id=313188&poll_id=&news_id=&page=2
Siebert Optics makes an OCA specifically made to work with the Burgess and most reflectors. They also make a Multimag adapter that will work with reflectors and refractors alike.
If you have an SCT you do not need an OCA to reach focus. Also since a Burgess binoviewer has such a short light path, some refractors will focus without an OCA.
I have a TAK FS-128 and I can use my Burgess binoviewer without any corrector. I also have an 8" Orion Atlas and half of an XT10. These need an OCA to reach focus.
Don Durbin
