14" Tscope big jump from C9.25?
Started by adamsdp, 04/05/2005 12:55PM
Posted 04/05/2005 12:55PM Opening Post
I am thinking of getting a Tscope 14" and if anyone has compared it or similar with a C9.25? I just sold a Astrosystems 12.5" Telekit which was a nice scope. The Telekit was brighter on deep sky objects from my
light polluted driveway but not enough of a difference to want to keep it. I did some comparisons between my C8, C9.25 and 12.5" on M36,M37 & M38 and the C9.25 seemed liked it performed closer to the 12.5" than the C8 which I did not expect. These are all relatively new scopes with the C8 having xlt coatings, C9.25 starbright coatings and the 12.5" has enhanced aluminum coatings.
The Telekit was on the heavy side for a 12.5" so I thought a Tscope 14" might be a significant jump over my C9.25 on deep sky objects and lighter than the 12.5" Telekit to make it easier to get out to dark sky locations.
A 14" Tscope is lightweight (35lbs mirror and rocker box) and is about as big a scope as I would want to haul into and out of a car. I do most of my observing from my driveway and the Telekit on a rolling platform was very quick and easy to setup. Thanks!
Posted 04/05/2005 01:27PM #1
Dave,
IMO the best way to measure aperture jumps is not in perceived differences in brightness, but in how deep each scope can go visually. I've seen nights where the brighter DSOs looked quite similar (in brightness) in my 16" and others' 14" and sometimes smaller scopes. However, when we point at really faint objects, such as the Horsehead (with H-beta filter) or Stephan's Quintet, I've rarely seen a smaller aperture scope keep up. Another test is fine planetary detail, but this often takes good seeing and specific planetary observing experience to discern critical differences in detail. Once again, IMO, most observers cannot tell differences in brightness of less than 15-20% on bright objects, but if you are viewing nearer the limit of your scope, the differences are more profound and if the seeing is decent the improvement in contrast (of a newt vs an SCT) and resolution of a larger instrument is very apparent to the experienced eye.
I would consider the jump from a C9.25 to a 14" Tscope to be huge based on all this. There are simply many, many more objects that can be viewed with the 14" that will not be seen in the 9.25" due to the superior contrast, light gathering and resolving power of the 14. But, you may not discern this so easily by simply comparing views of the brighter DSOs.
Best wishes,
Randy
Randy Roy
Posted 04/05/2005 06:13PM #2
Normally I would say that a 14" is a big improvement over a 9.25". But I would also say that it was not a big improvement over a 12.5". So my main comment would actually be that if you want to see a big improvement, get to a darker site.
I have had scopes from 80mm to 18". On DSO's, the number 1 thing is dark skies. The 80mm will literally show you almost as much from a dark site as the 18" will from a heavily light polluted site. A 10" will show far more from a dark site than an 18" in light pollution. If you didn't notice much improvement in the views with the 12.5", then I suspect the culprit is light pollution. If the background is as bright or brighter than the object, no amount of aperture is going to increase the contrast (you have to have some contrast to start with).
So, at a dark site, I would expect the 14" will be significant improvement over the 9.25". But I think taking the 9.25" to a dark site will be better than the 14" in your dirveway, at least for DSO's. If the 14" has good optics, it should also do better on the moon, planets, small glob's, doubles, and with a good filter will probably do better on small nebula's too. Those will all be benefits even under light pollution, but the faint stuff really needs dark skies.
Jarad
