15" Split-tube, first light.
Started by fblue, 03/21/2004 10:23PM
Posted 03/21/2004 10:23PM Opening Post
I am not trying to undermine Discovery or their telescopes, but because I made posts earlier about the scope I thought I should bring these facts to the forum for your information.
Well, we went up to Pinos last night. It was not crowded, but about 20-25 scopes were there.
The viewing was good to excellent with some atmospheric disturbance to the west of zenith.
The night was pretty mild with nice temperatures and no dew. Winds were calm and no clouds blocked the sky.
My friend brought his Split-tube 15" Discovery and we had 1st light with it. Not bad, but the design and construction was not very good on the rocker box. It was out of square and the tube did not fit. The Alt bearings were too small and attached with staples. The sides were only 3/4" thick and the flex was extreme with the heavy tube on it. The DSC encoder mouting for the Alt is very poorly designed and required disassembly of the Alt bearing and handle with each set up or you can not use the handles provided for lifting. These are needed as the tube is quite heavy. It did not drive very well either, maybe new bigger bearings will help this. The optics were OK, but coma was almost excessive and their was a little off color due to the coma, but it is a f/4.2. But the performance was no where near my 15" f/4.9 on any object. But the Swayze mirror is better I guess and the fans on mine probably make a difference as well as the flocking and all. In all it was "OK" but certainly not exceptional. He has some work to do to make it more stable and drive better.
Floyd
