A question from a "newbie" about Naglers (probably
Started by perro, 07/29/2004 06:35AM
Posted 07/29/2004 06:35AM Opening Post
Hello,
I just recently jumped to a large
aperture dobsonian, having just
acquired an 18" Obsession. I have
been collecting eyepieces here on
Astromart for a little while now and
have, what is probably the stupidest
question ever asked--it will only
betray how green I am when it comes to
the "big stuff" smile (I've never owned
a Nagler, or any big, expensive ep).
On the 9mm & 12mm Naglers there is a 1
& 1/4 barrel to insert in the scope,
and in a little further, a 2" barrel.
The 2" has a little screw in it's side
that is tightened onto the 1 & 1/4
part. What is the screw for? How do
you use the 2" part for viewing since
the 1 & 1/4 part is in the way? Is
the 2" supposed to be used for
viewing, or is that just the way they
taper down to the 1 & 1/4? It just
seems to me that these ep's would be
2" & not 1 & 1/4--especially the
12mm. Is the 1&1/4 part removable?
Ok, I asked more than one question,
but I hope you get the jest of my
ignorance and can shed some light for
us little ep guys--it looks like some
kind of add-on for 1&1/4" scopes, but
I can't figure it out, and don't want
to venture taking apart an ep without
knowing what I'm doing. I'm sure
y'all will be laughing when you read
this wink , but you've got to ask
sooner or later--I'll go for sooner.
Kind Regards,
Chris Palacios
Posted 07/29/2004 01:06PM #1
THese are 1.25 eyepieces with a convenient and permanently installed two inch adapter. THey perform just like a 1.25 eyepiece should, and get no optical benefit from the two inch adapter. To use them, just unscrew the screw that gets in the way of the focuser tube.
By the way, don't disassemble and remove one of the sizes of tube--you will find them useful at different times with different scopes. And neither really interferes with the other.
And if you think this is a dumb question, just realize that it has been asked many times before, (even on this forum in the last couple of months......I used to ask this same question.
