Ghost of Cassiopeia
Aberrator- F-ratio, obstruction and planetary
Started by Ron777, 07/21/2004 06:08PM
Posted 07/21/2004 06:08PM | Edited 07/21/2004 06:10PM Opening Post
After all this talk about Maks Vs reflectors, etc. I took an image of Jupiter into the aberrator program and generated some samples. I wonder how accurate this software is?
Seems to show that F-ratio makes more of a difference than obstruction size.
I enclosed a pic here,
First pic is raw image
Second is my scope, 10 inch F5.6 about 20% obstruction (amazingly is exactly how I see Jupiter in my scope in good seeing, hoping that means the rest are accurate too)
Third and forth images are 6 inch scope F10, with both 20 and 35 percent obstructions. The 6 inch with 35% looks a bit better than the 10 inch F5.6 as far as sharpness and contrast.
Thoughts on this?
Thanks, Ron
Ron777's attachment for post 17553
Posted 07/21/2004 06:34PM #1
I can see details a bit better than the scopes shown, on a good night, with my 12.5" f/4.8(20% CO) and 15" f/4.9(17% CO) Dobs. There are times when you can clearly see the festoons and minor bands and the GRS. I think that the atmosphere is more responsible for what you see than the central obstruction.
Floyd
Posted 07/23/2004 05:56AM | Edited 07/23/2004 06:02AM #2
Hi Ron,
I played with the Beta version of this program, and it seems the first planet rendering I did came out a little rough. I then re-calculated it again, and it came out better. All subsequent renderings seem to be about right. It is just the first one that seemed too soft.
Which version are you using ?
Here is my attempt at rendering with different CO's. The bottom left is the raw image, then clockwise is a perfect 10" unobstructed simulation (dream APO?), note some of the fine detail is lost. Then a 10 inch with 12% CO. I cannot tell much difference here between 0% and 12%. Then the last shot is a 10" with 20% CO. Now the difference is subtle, but it is there. Some of the central banding soft detail seems to get washed out in the 20% CO case. My general impression is the high frequency detail is about the same, it is just the subtle soft details that get affected with the larger CO.
Although I would be proud to have a scope that gave images as good as the 20% central obstruction image : )
It would be interesting to run these images through image sharpening programs to re-introduce the details that are starting to fade out, and compare them to the original image.
David Simons
David Simons's attachment for post 81607
David Simons
