Philip Imbrogno
Elephant Trunk Nebula
Adapter for Nikon Digital 5400
Started by mvollmer, 03/22/2005 12:00AM
Posted 03/22/2005 12:00AM Opening Post
Please forgive me if this is not the correct forum for this question, but I am wondering if there are any companies that make an adapter to fit a Nikon CP5400 digital camera to adapt to T-threads. I'm thinking of something that may not be as elaborate as the Scopetronix piece. I have both 1-1/4" and 2" extension tubes that are threaded with T-threads, and all I really need is an adapter to fit between the camera and extension tube. Any ideas from the forum? If this is not the right forum for this, you may reply to me off-line.
Thanks
Mike V.
Posted 03/25/2005 02:50PM #1
Mike,
You are right, that should work. However, the way the snout of the 5400 is designed, you will need to attach that adapter to the camera itself and not the lens. Which means it needs to be recessed just like the Scopetronix adapter is.....in short, I think if you wind up getting the scopetronix type piece anyway.
I have lots of adapters, and a 5400. I'll go see if I can get anything to work.
Posted 03/26/2005 03:33AM #2
Mike,
Well, I went experimenting. And I think it isn't going to work.......
The problem is that as soon as you turn the 5400 on, the nose (the lens) has to pop out. So, whatever you attach up there has to be bigger than the lens. So, whatever you buy is going to be something like the Scopetronix affair.....and probably cost as much.
Second problem, I think any existing projection photo adapter will not work because you could not get the lens of the camera close enough to the eyepiece you are using for projection. This is the great strength of the Scopetronix system......you are right there on the eyepeice. If you don't do this, you are going to get severe vignetting.
And besides, nobody else has volunteered an answer. So, I don't think such an adapter exists......Of course, Scopetronix would know if anybody.
