I need to collimate a 6" refractor which I have just built a new tube for and does not have an adjustable cell.
Please advise me if I'm wrong, but I think collimation will involve first being sure the focuser is square. Then once that is done, I would proceed to make sure the ojective is square.
I planned on using a laser collimater for this process. I would first square the focuser by using a paper template over the lens with a hole dead center. If the light passes through the hole, we are good.
Next to square the ojective I would use the collimator with the dew cap on and check the reflection. I would adjust the cell until there was only one centered beam.
Does this sound correct or have I not thoroughly thought the process through?
thank you, Bill
thank you, Bill
