james carter
North American Nebula NGC7000
AFOV on LV's
Started by pjbilotta, 12/15/2003 09:34PM
Posted 12/15/2003 09:34PM Opening Post
I know there is probably a very simple answer for this. Many long eye relief eyepieces like the Vixen and Orion Lanthanums drop from a standard 50 degree FOV to 45 degrees once your get into the sub-7mm range. Why is this?
Yes, I know it is all determined by the physical field stop between the upper and lower elements, but why is this narrower field necessary? What happens to the usable field if the stop is removed?
Just curious.
Posted 12/15/2003 10:12PM #1
The narrower field is obviously not necessary in general when it comes to long eye relief and short focal lengths (witness the Radians, Pentax XWs, and Pentax XLs, not to mention the Vixen LVWs), but it may have enabled them to make the LV eyepieces a little bit less expensive by allowing them to retain a simpler field group design. It may also have helped them to keep the eyepieces relatively short in size. Possibly what you would see if you removed the field stop is a slight increase in usable field and vignetting such as is often observed with long focal length Plossls and short Barlows.
Mike
