My stock of 1968 Optical Craftsmen vintage supplies includes two "anti-slip rings" or stop rings. These prevent the tube from slipping forward or backward.
They are a bit trickier than they look. They don't make 100% contact against the tube rings; they only turn against the nylon screws that stick out from the tube rings.
yesterday I got everything balanced just right and tightened the stop rings down with each one touching the tube ring above/below it.
This turned out to make it very difficult to rotate the tube. If two rings are making contact against the nylon screws you have twice as much friction.
So I had to put a little play into the adjustment. Now the rotation is easy but the tube is capable of about 1/4 inch movement. I might be able to narrow down the play but the stop rings are not 100% in the same plane.
Anyhow I think this is a very antique consideration. I'm not sure anyone will know what I'm talking about....
Greg N
(similar post on CN)
Greg N
