Jay Messeroff
Lunar & Solar Transits
Any low power Barlows out there?
Started by Inge_S, 03/08/2004 01:18PM
Posted 03/08/2004 01:18PM Opening Post
Finding a barlow giving an increase of 2x or more in magnification seems to be quite easy. However, I'm looking for a barlow giving a lower magnification, perhaps 1.5x or 1.8x. Does anything like this exist on the market?
One additional question for the optical specialists: Will a low power barlow improve the edge definition of a low power eyepiece with a wide-field eyepiece. More specificly: How would this combination work:
12.5-inch 1/4.8 mirror + 1.5x Barlow + 30mm 80 degree BW EP
Posted 03/08/2004 02:01PM #1
Hands on Optics sells a 1.5X 2 inch Barlow.
It would probably improve it somewhat, simply because it is effectively changing the light cone/focal ratio from F4.8 to F7 or so. I have one of the BW-Optik eyepieces and it is not anything to write home about in an F6.9 Pronto and as you know really quite problematical in an F5 Newt.
But I quesstion the wisdom of spending $150 on a barlow to improve the performance of a $95 eyepiece. First you are effectively reducing the focal length of the eyepiece from 30mm to 20mm, and for $150 you can buy some pretty decent widefield 20 mm eyepieces. The Antares 20mm with the 70 degree FOV is only $50 and if it is similar to the 15mm its a whole lot better than the BW_Optik 80 degree 30mm.
Second, for that $150, there are used 2 inch eyepieces that are far better than the BW-Optik. I bought a 32 mm TV Widefield off Astromart for about that and while it only has a 66 degree FOV, the edge correction and overall view is far superior to the BW-Optik. I find it near perfect in the Pronto, very acceptable at F5 in a Newt and usuable at F4.1.
jon
Posted 03/08/2004 03:29PM #2
Inge,
Rick Blakely designed the Uranoport 1.5x barlow. See www.uranoport.bigstep.com. It advertises as a high quality unit, and he has a good reputation as an optician here. I haven't used it myself.
Mike Ratcliff
Posted 03/08/2004 05:27PM #3
Televue used to make a 1.8X barlow, and while they are no longer made, you can still occasionally find one used on Astromart. I own one, and like all TV products, it's quality is outstanding.
Posted 03/09/2004 06:38AM #4
Thanks all of you for useful advice. I'm not really in a hurry, but on within some time I plan to aquire one eyepiece for low power wide-field use, and a low power barlow will be a good supplement to my present 2.8x Klee.
I also have a gap in the high magnification range, and seriously consider one of the TMB monocentrics. The field is small, but it is very fun to use (giving me a "retro" feeling).
