Here's a thought....
A statement we always see, "I was able to view at X power with no image breakdown"
Will using a shorter focal eyepiece actually damage the image formed by the main optics, that is floating at the focal plane? Naaaa!
All were doing is 'seeing' the raw image on a larger scale. The fixed optics of the scope are projecting the image at the focal plane. Changing eyepieces will not affect the raw image, it only let's us get closer to it. If you look at a picture in the newspaper with a magnifying glass, the picture doesn't 'break down', you just see the dots it's made from. It's less pleasing, but still the same image. If Saturn looks good at 150 but not at 300, all that means is you can now see the defects at the larger image scale.
So... why can we use higher power with larger scopes? I have never seen the 'dots' that make up the image no matter how high in power I went? Somehow, larger aperture must be (generally), putting up a cleaner raw image.
I can print off a picture at 50 DPI, and another at 600 DPI. If both are clean crisp images, I can blow up the final picture as large as I want. The 50 DPI will have less detail but will never 'mush out' or look 'out of focus'.....
