I'm thinking about buying a small scope for multiple purposes including quick night viewing, nature observing, and using as a telephoto lens for my digital camera. I've been following the information about the upcoming William Optics 60mm (achro or semi-apo ~ the marketing literature doesn't make that too clear) and also see where Apogee is offering a low-priced ($130) rich=field 80mm scope. I was wondering if anyone has tried the Apogee?
Apogee Rich Field 80mm
Started by davidcolton, 11/24/2004 03:21PM
Posted 11/24/2004 03:21PM
Opening Post
Posted 11/24/2004 04:55PM
| Edited 11/24/2004 04:56PM
#1
I have one that I bought about a month or so ago. There are several problem areas.
The focuser has the "chinese glue" that must be removed and relubed. Even then there is a little backlash left but it is usable.
The rear baffle that is located in the end of the drawtube leaks light around the outer edge that SEVERLY degrades the image contrast. Once that is repaired it makes a huge improvement.
The 45* diagonal is a POS bigtime! Mine had a casting defect right down the middle of the PLASTIC prism. Throw it away and go to a quality 2" of 1.25" diagonal.
The 18mm K ep is actually quite nice, sharp and contrasty.
I have used it with a 3.8mm ep to resolve the double double, but had to add a light yellow filter to remove the slight blue haze.
However, with a 2" 30mm 82* fov ep, 2" diagonal it gives really good wide field views.
For the price it is a good deal but it will require the tweaking above to make it usable.
FWIW
Walt
FWIW
Walt
Funding Member
Sponsors
- APM-Telescopes
- astronomy-shoppe
- Desert Sky Astro Products
- RemoteSkies.net
- AstroMart LLC
- Astromart Customer Service
- Vernonscope
- Matsumoto Company
- Anacortes Telescope
- Waite Research
- FocusKnobs
- CarbonScopeTubes LLC
- OMI OPTICS USA LLC
- BW
- kwtelescope
- SellTelescopes.com
- BBLABS LLC
View all sponsors
