The company Aries in Ukraine with Valery Deryuzhin is known to some but not all people. Valery is my very old friend and a person with great Ideas in mind. Some revolutionäry Idea's he have had ,he realist and some others not.
2 well known products are the Aries Chromacor , a color corrector for achromats and the Aries Safix , a spherical aberration corrector.
With the Aries Safix, from which I got a some handfull for sale, my little and short review is held tonight.
We at APM build our own Apo Telescopes, but me , Markus , is a fan of any high quality Apo Refractors, no matter who is the manufactor. I like quality ! Due my love to high quality Apo's, I have once and a while all kind of manufactors apo's in my hand , to play with and have fun.
Tonight I compared from 1 manufactor 2 diffrent high quality apos, a f/8 triplet against a F/8 douplet , to see how the work against each other, how the colorcorrection compares under sky, how the starbluring and cool down is doing against each other and and and.....
The F/8 triplet has of course the better colorcorrection and it shows at first view a great Startest. The F/8 douplet has a excellent colorcorrection and a stunning perfect Textbook Startest , as perfect as it can be. If you see the startest of the douplet against the startest of the triplet, then you would agree with me saying well the startest in the triplet looked superb before the douplet arrived, but now compare to the douplet, this triplet startest is only good and not anylonger perfect.
Objects of this late evening in the both scopes has been douple stars, single stars of diffrent color and Saturn.
First I started with the F/8 douplet and pushed the power up tp 410 power = 102 x per inch .
Saturn looked racersharp and bright , visible brighter then later in the triplet modell.
Single stars and douple stars showed almost no halo , but I need to say I did not use Sirius or other bright stars, but first magnitude Stars only.In defocused image this douplet show very little hint of green at one side and purple at other side fressnell rings. Fresnell rings are those rings in the inner part of the defocused starimage. The outer bright rings of this douplet looked at any power perfect identical/symmetrical.
The Aries Safix addet to this douplet apo with perfect optics did not damaged much and did not improved anything , because a perfect optics cannot be made better. But playing with the Safix at this scope is worth a teaching course for anybody who like to learn a bit about optical and startesting. But rotating the Safix you can introduce from mild spherical aberration to horrible big amount of spherical aberration. Its a bit like playing with the Aberrator software.
Then I switched to the triplet , I saw superior colorcorrection, a great looking startest at lower to middle power, but when I went into the high power I could see more and easier in the very little defocused image, how the outside focuse image starts to differ more and more from the inside focuse image.
What jumped immediatly to my eyes, was that I could see the diffraction rings clearly brighter as in the douplet. I switched 2 more times the scopes to be shure and yes I was right. The triplet prooved to have a mild , not much , but visible for scilled eye, spherical aberration.Now I took the Aries Safix and wow , I was able by finding the best rotating position , to see now a same perfect startest as in the douplet , but better colorcorrected in the triplet. The diffraction rings became as faint in the triplet as I saw before in the douplet. So the Safix does his job here very very well.
Now I pointed the triplet to Saturn and thought, hey a nice image, but moments of best seeing looks like they have gone, I did not got the same racersharp image as in the douplet. So I thought, ok, let see what the Safix can do here , at one side he shall correct spherical problems, at the other side, I have with Safix more lenses in front to look through , a bad compromisse ???????
Putting the Safix into the triplet and playing a little with the tuning, I got shocked how much the image improved . Before I thought the seeing does not allow to see the super sharp image , but now with Safix I found the same sharp image in the triplet as with the douplet and I could see clearly better ring splitting and cloudbands on the saturn surface. So Safix does indeet do a clear visible detail improvement on this scope, where I thought before, it has already great optics.
About an half year ago I found also that this Safix did a superb improving on a petzval Apo . So Safix prooves to work well in diffrent kind of scopes.
From now on the Aries Safix will be always with me , a, to play with it and show to friends and customers how diffrent startest can look like, and b, to improve the images formself too.
I will have the Safix end of the month at NEAF show and will demonstrate there a little bit what it can do.
My Congratulation to Valery for this next superb idea.
clear skies
Markus Ludes
clear skies
Markus Ludes
clear skies
Markus Ludes
APM-Telescopes/Germany
