Baffles in a DOB
Started by fblue, 10/13/2003 07:35PM
Posted 10/13/2003 07:35PM Opening Post
Has anyone ever made a DOB with internal light baffles?
If so, where did you place them?
Did they do any good increasing contrast?
I have flocked the secondary with good results, sky appears a bit darker, and have flocked the inside of the hole for the focuser tube. Not sure whether it made any real changes.
I am trying to get the best constrast possible with my DOB. Any suggestions would be appreciated.
Floyd
Posted 10/13/2003 07:44PM #1
I would think that baffles inside a DOB are self defeating ... unless the tube diameter is much larger than the mirror. Why would you fill a bucket using a funnel?
Also, "flocking the secondary" would definately give you a dark background ... along with everything else. Did you actually mean flocking behind the secondary (across from the focuser)?
Posted 10/13/2003 08:12PM #2
Posted 10/15/2003 06:07PM #3
Floyd -
I installed baffles in my 13" homemade dob a few years ago and indeed they helped improve contrast. I consistently get compliments at star parities regarding the high contrast images that scope provides.
There are 12 baffles (the tube is 16" ID), made from 3/16" foamcore board, which is both stiff and light. The problem is the thickness. I trimmed each one so that they were tapered to a sharp edge at the aperture. I calculated the size and spacing using a method I found off the ATM web site (I recall www.tiac.net/something) back then, but that site now seems to be defunct. I've looked but can't seem to find it. Rich Combs may have been the author, I find hyperlinks in various places but the site is gone.
I understand that baffles in a newt can force warm air into the light path, and I've always had pretty bad thermal problems in that scope. I'm in the process of installing blow-across fans w/vents at the mirror end and I'm hoping that this will help.
Good luck,
Doug Scobel
